CONNECT feedback portal
Categories General
Created on Apr 15, 2025
Allow client-level failover on a per data source component level
Currently the client-level failover for Adapters occur on a per Adapter level. Which means that for instances where multiple data sources are configured, in some circumstances failover may result in an instance with a bad connection to a particular data source becoming primary, despite the other instance still having a good connection.
The only way to get the client-failover mechanism to be separated by data source is to either install multiple instances on multiple machines or use Docker containers (currently only supported on Linux).
Example:
Adapter1 & Adapter2 configured in failover with three data source components configured with equal number of streams.
Component1 -> DataSource1
Component2 -> DataSource2
Component3 -> DataSource3
On Adapter 1 - connection to DataSource1 & DataSource2 goes bad, but DataSource3 is good
On Adapter 2 - connection to DataSource3 is bad, but DataSource1 & DataSource2 is good
This will result in Adapter2 being the primary and data flow from DataSource3 will be interrupted.
  • Kenneth Barber
    Aug 12, 2026
    That is quite the oversight in the failover mechanism, but good catch! You never want your connection to a data source to fail just because using the other AVEVA Adapter instance is the overall better choice. Why pick the lesser of 2 evils when you can just avoid the evil?
