CONNECT feedback portal
Created on Apr 13, 2026
PI Tag Mapping configuration in the background of PI OPC UA Adapter to use Point ID
The CSV / JSON file in the background will have the mapping between the OPC UA Server tag against its' respective PI Tag Name. In such case, if we need to change the tag name after sometime, then which results in multiple process like stop the Adapter, Rename the tag in PI DA, reflect the new name in the CSV / JSON file, then start the Adapter. Instead of this long process (which sometime has indirect downtime), we can have the mapping in the CSV / JSON file, like OPC UA Server tag against its' respect PI Tag Point ID. So that, the renaming of the tag doesn't really need any activity to be performed against the Adapter node.
This is same case in Connector as well.
  • Kenneth Barber
    Jul 12, 2026
    This idea is fine as long as it doesn't replace the option to use tag names.
