CONNECT feedback portal
Categories General
Created on Aug 16, 2022
Support outputs/write data from PI Adapters
No description provided
    Dec 6, 2024
    In the industry the demand for secure & native OPC UA integration is increasing.
    Ability to make PI data available through OPC UA protocol is certainly something what should be addressed by AVEVA.
    Either an PI OPC UA Server to allow connected applications to pull PI data using OPC UA, or, as suggested here, to have an Adapter to push data into external OPC UA Servers
    Complexity might be the fact that Adapters are not designed to read from their OMF endpoints.
    Eagerly waiting to understand the AVEVA roadmap. Usage of DA/UA wrappers should only be a workaround
    Oct 20, 2023
    see here also the same requirement specifically for opc ua adapters
    https://pisystem.feedback.aveva.com/ideas/PIADAPTERS-I-50
    Aug 16, 2022
    I need to be able to send a command to the data source so that I can remotely shutdown / failsafe a monitored asset in case a problem is about to happen.
  • Kenneth Barber
    Aug 16, 2022
    If writes are required, it might be best to have read-only and write-only versions of the PI Adapter. See this suggestion for more details: https://feedback.osisoft.com/forums/555142-pi-interfaces/suggestions/40997296-separate-commonly-used-pi-interfaces-into-read-onl
